查看: 185|回复: 1
thermoking apu
 楼主| 发表于 2021-1-8 22:33:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"Does anyone have an apu on their truck and notice that the side that it's installed on the frame slouches slightly? Which makes the cab airbag and the rear airbag suspension on that side to be higher than the other side? it's not so bad on smooth flat roads but any rough roads or camber and you really notice how off balance it makes the truck feel.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-1-9 00:27:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"No, APU only weighs a couple hundred pounds. Should have no effect on your suspension. ","replyToPid":0}
GMT+8, 2026-4-21 08:07 , Processed in 0.070443 second(s), 24 queries .
