查看: 364|回复: 13
cant hear anything from my cb
 楼主| 发表于 2021-1-2 02:49:52 来自手机 | 显示全部楼层 |阅读模式
{"text":"just bought a cb everything is hooked up it turned on but I cant hear anything\n\nthanks for all the help I got through to a person on channel 3 is that the one people use? I decided to read the manual and calibrated all the channels \n\nlol channel 19 google is your friend I was trying mainly channel 9 because it has a setting for channel 9 though that was the good one","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2021-1-2 06:24:58 来自手机 | 显示全部楼层
758212 发表于 2021-01-01 21:09:32 Squlech is turn to the right to turn dwn
","text":"Not on any radio I’ve owned in the last 30 years","replyToPid":412622}
发表于 2021-1-2 05:09:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Squlech is turn to the right to turn dwn","replyToPid":0}
发表于 2021-1-2 06:30:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dinosaur 🦖 ","replyToPid":0}
发表于 2021-1-2 03:41:34 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"1 make sure it’s on CB not PA\n2 Squelch all the way down (turn left)\n3 RF gain all the way up (turn right)\n4 make sure antenna is screwed in\n5 make sure proper microphone is        installed. Not all radios are wired the same on the mic.\n6 If a multi band radio make sure AM is selected. Knob might say CW,FM,USB,LSB,AM"}
发表于 2021-1-2 03:13:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"make sure speaker plugged, not in pa","replyToPid":0}
 楼主| 发表于 2021-1-2 03:37:45 来自手机 | 显示全部楼层
498454 发表于 2021-01-01 19:13:26 make sure speaker plugged, not in pa
","text":"it's on the cb setting I do head staic","replyToPid":412612}
发表于 2021-1-2 03:44:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"“Can’t hear anything” could mean a dozen things as usual. A little\nClarification would help , also maybe a make and model of the radio.","replyToPid":0}
 楼主| 发表于 2021-1-2 03:55:03 来自手机 | 显示全部楼层
936953 发表于 2021-01-01 19:41:34 1 make sure it’s on CB not PA\n2 Squelch all the way down (turn left)\n3 RF gain all the way up (turn right)\n4 make sure antenna is screwed in\n5 make sure proper microphone is        installed. Not all radios are wired the same on the mic.\n6 If a multi band radio make sure AM is selected. Knob might say CE,FM,USB,LSB,AM
","text":"my red ant light is off","replyToPid":412616}
发表于 2021-1-3 21:31:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Keep in mind, Ch9 is the EMERGENCY Channel and used to me monitored by Police (not sure if they still do or not)","replyToPid":0}
GMT+8, 2026-4-16 12:24 , Processed in 0.085568 second(s), 24 queries .
