查看: 648|回复: 11
Rookie trucker
 楼主| 发表于 2020-12-27 11:14:54 来自手机 | 显示全部楼层 |阅读模式
{"text":"Only been driving for about 4 months. I have had some real heavy loads but now I got one that’s 40,533 pounds which I have had more than that but this load is weird. I’m not over 80,00 but no matter which I slide my tandems. I’m still overweight on my steer tires. Weighed myself bout 5 times still didn’t get under 11,500. What happens if I get an overweight ticket?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-12-27 11:30:06 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"another muppet account\ndid Kermit give you your license?"}
回复 支持 8 反对 6
发表于 2020-12-27 12:59:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Can we say needs retraining ","replyToPid":0}
回复 支持 5 反对 5
发表于 2020-12-27 13:51:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can go up too...\n\nSteers 12,000\nDrives 34,000\nTrsiler 34,000\nTotal    80,000","replyToPid":0}
回复 支持 8 反对 1
发表于 2020-12-27 13:54:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Try getting a life","replyToPid":0}
回复 支持 4 反对 4
发表于 2020-12-27 12:41:46 来自手机 | 显示全部楼层
1055926 发表于 2020-12-27 03:30:06 another muppet account\ndid Kermit give you your license?
","text":"yup","replyToPid":412262}
回复 支持 4 反对 3
发表于 2020-12-29 23:09:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"you can be 12200 too or 34250 etc, as long as overall u r 80k or under.... u gotta meet a true ickd head of a inspector to tkt...\n\nremember a) u can also slide ur 5th wheel to distribute the weight and b) if u r nearly touching 80k or are very tight to the limit on drive axle then pay attention to the fuel lvl u are at, dont go beyond that  c) pay attention at docks as to how they load or after they done, observe and see if you can make some sense out of what they have done, better take the extra 5-10 mins there and right away realize something is wrong then go to scale, adjust 3-4 times and still realize its not gonna work, d) there is a drive axle weight gauge in your truck, get accustomed to that, as to what does it tells you and where the tandom is, how trailer is loaded etc, for example in my freightliner, if my load is 40k then i know i am around 77k overall, then i see is the load balanced and all the way to back, which hole is it in, and look at the drive axle gauge, it shouldnt be past way 60... but right around it... if it is way off either way, i know right there either i gotta move my tandoms or if the tandom is in a decent spot but the air gauge is way off then they have loaded me improperly...\n\nhope this helps...","replyToPid":0}
发表于 2020-12-27 22:19:45 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"yw"}
发表于 2020-12-29 13:46:21 来自手机 | 显示全部楼层
941089 发表于 2020-12-27 05:51:24 You can go up too...\n\nSteers 12,000\nDrives 34,000\nTrsiler 34,000\nTotal    80,000
","text":"Thank you for giving the answer. We have to lift each other up and help out... so sad... ","replyToPid":412269}
发表于 2020-12-28 09:24:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"can try sliding your fifthwheel but if its heavy in the nose you're gonna have to rework the load and put the weight in the belly","replyToPid":0}
 楼主| 发表于 2020-12-27 20:52:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks PAIGEY everyone else can shove it up there ***","replyToPid":0}
发表于 2020-12-27 22:51:48 来自手机 | 显示全部楼层
","text":"12500","replyToPid":412269}
GMT+8, 2026-4-21 13:32 , Processed in 0.159742 second(s), 24 queries .
