查看: 221|回复: 7
that is scary
 楼主| 发表于 2020-12-20 20:23:50 来自手机 | 显示全部楼层 |阅读模式
{"text":"youtu.be","videos":"[]","link":"{\"picture\":{\"description\":\"\",\"height\":180.0,\"name\":\"\",\"url\":\"https://img.youtube.com/vi/vYrI3d5BN9Q/mqdefault.jpg\",\"width\":320.0},\"title\":\"YouTube\",\"type\":\"VIDEO\",\"url\":\"https://youtu.be/vYrI3d5BN9Q\",\"valid\":true}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-12-20 21:26:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"no headache rack? no stop on front of rebar? or blocks turning it up? (unless it had overhang) no chains and binders?  driving to fast rear ended a semi.  Idiöt lucky to be alive. wrecked a beautiful classic.","replyToPid":0}
发表于 2020-12-21 00:37:42 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"No load securement+no headache rack+no bulkhead+driving like an ìdiot=epic fail."}
 楼主| 发表于 2020-12-21 01:30:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"he look like old school experienced driver ...id like to know his version.  can t imagine the speed and the brake to jump from trailer, thru the straps all the way in to the engine... had loads like that a bunch (straps only /chains only) didn't move a inch.. his load it s a new level of f** up","replyToPid":0}
发表于 2020-12-21 06:58:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"it would be interesting to hear his version. Like you guys have said, was a very poor securement job. Does not look like he even belly wrapped it. Seems at times the old schoolers are the ones that take securement shortcuts. They think, been driving all these years and never had it happen.","replyToPid":0}
 楼主| 发表于 2020-12-20 20:48:41 来自手机 | 显示全部楼层
766797 发表于 2020-12-20 12:42:40 many do it daily but that's not meant they do it correctly ........
","text":"true that. Idk how he still got legs.","replyToPid":411624}
 楼主| 发表于 2020-12-21 08:37:36 来自手机 | 显示全部楼层
925557 发表于 2020-12-20 22:58:46 it would be interesting to hear his version. Like you guys have said, was a very poor securement job. Does not look like he even belly wrapped it. Seems at times the old schoolers are the ones that take securement shortcuts. They think, been driving all these years and never had it happen.
","text":"was thinking thesame,  overconfident based on years of experience","replyToPid":411677}
发表于 2020-12-21 12:39:46 来自手机 | 显示全部楼层
721674 发表于 2020-12-21 00:37:36 was thinking thesame,  overconfident based on years of experience
","text":"Watched an old timer the other day load a 45,000 pound coil suicide. He used 2 direct tie 3/8 \" chains, threw 1 strap over the top and took off. No way that would hold that coil if he had to dynamite his breaks or swerve for some reason.","replyToPid":411680}
GMT+8, 2026-3-21 04:41 , Processed in 0.089236 second(s), 24 queries .
