查看: 377|回复: 17
Hi everyone
 楼主| 发表于 2020-12-17 13:22:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi I am a new driver, any tips info you will like to share. will sure be appreciated. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2020-12-17 14:15:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"I was able to unlock it but unable to figure out how to close the lock","replyToPid":0}
发表于 2020-12-17 22:55:08 来自手机
{"replyTo":"","text":"Take a shower often 💦 ","replyToPid":0}
支持 2 反对 0
发表于 2020-12-17 15:25:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"welcome to the profession, being a new driver in the winter has its challenges. if you don't feel safe park the truck. a customer would rather have a late delivery than no load at all. don't let your driver manager pressure you to drive in adverse weather. if you have questions about your load or delivery area ask your driver manager.","replyToPid":0}
发表于 2020-12-19 03:40:28 来自手机
{"replyTo":"","text":"Stay away from swift trucks lol","replyToPid":0}
支持 1 反对 0
 楼主| 发表于 2020-12-17 14:14:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thank you, do you know about moving the fith wheel on a kenworth t680 2017?","replyToPid":0}
发表于 2020-12-17 13:32:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hi sista just keep a cool head dont get fluster n make wrong decisions n dint let people force u to do what ur not comfortable with","replyToPid":0}
发表于 2020-12-17 15:39:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"a tip I'll let you in on is I advise avoid using the in cab fifth wheel release if your truck has it. There is a defect in the newer trucks air piston the the airline runs to unlock the fifth wheel. common to become seized render your fifth wheel unusable even manually once it's seized.","replyToPid":411254}
发表于 2020-12-17 14:45:16 来自手机 | 显示全部楼层
1053607 发表于 2020-12-17 06:15:15 I was able to unlock it but unable to figure out how to close the lock
","text":"Down the landing gear of the trailer that make it easier to move the fifth wheel and lock down the pins ","replyToPid":411248}
发表于 2020-12-17 15:35:55 来自手机 | 显示全部楼层
1053607 发表于 2020-12-17 06:14:33 Thank you, do you know about moving the fith wheel on a kenworth t680 2017?
","text":"I do","replyToPid":411247}
发表于 2020-12-17 15:36:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"I was running a 2018and 2019 Kenworth T680 before my current 2013 Kenworth T660","replyToPid":411254}
发表于 2020-12-17 15:39:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hello","replyToPid":0}
GMT+8, 2026-2-4 23:07 , Processed in 0.099385 second(s), 24 queries .
