查看: 387|回复: 10
Front axle weight problem with 2017 volvo vnl 780
 楼主| 发表于 2020-12-15 01:20:58 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello drivers (colleagues), I have a problem and I would like to find the best solution. I have a volvo vnl 780, 300 gallons tanks and APU, 3.08 ratio (automatic) transmission so even when I don't have a load (when I'm empty) only with full tanks I'm close to allowed  limits on the front axles (about 11500).  I pulled the trailer back to the 5-wheel so in the winter my fuel consumption is much higher even when I don’t have a heavy load (about 6 gallons), I’m driving dry van 53ft. I read somewhere that some trucks are allowed to weigh up to 13,200 pounds on the front axle (total weight must not exceed 80,000 pounds)? !!  Does anyone know anything about this information","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-12-15 01:52:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"I see your problem. The problem here is it seems to me you have a VNL 780. Take her to the bone yard. I think youre just going to have to put her down. 😞","replyToPid":0}
回复 支持 9 反对 0
发表于 2020-12-15 03:05:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Open your drivers door, look for the tag that shows axle ratings for your truck. A steer axle can have up to 20,000 pounds on it depending on axle spacing and rating. If your truck is equipped with a 13,200 axle that’s your limit. ","replyToPid":0}
回复 支持 7 反对 1
发表于 2020-12-15 03:07:14 来自手机 | 显示全部楼层
936953 发表于 2020-12-14 19:05:46 Open your drivers door, look for the tag that shows axle ratings for your truck. A steer axle can have up to 20,000 pounds on it depending on axle spacing and rating. If your truck is equipped with a 13,200 axle that’s your limit.
","text":"I should have added to check the weight limit on your tires to make sure they are also rated for at least your axle limit. ","replyToPid":410857}
回复 支持 4 反对 1
发表于 2020-12-15 14:13:33 来自手机 | 显示全部楼层
{"replyToPid":410898,"replyTo":"
1043685 发表于 2020-12-15 03:37:31 Also with APU you are allowed to gross 80,500#
","text":"Unfortunately that’s not a federal mandate. So each state has its own discretion on wether to honor that. Not all states honor the APU exemption. Here’s a list of states for anyone interested https://www.trackyourtruck.com/blog/apu-weight-exemption-guide-state/"}
发表于 2020-12-15 11:35:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can haul whatever your steer tires are rated for. I run 16 ply steers on my 13,200# steer axle Peterbilt 389. At 80,000# I’m usually 12,600# on my steers. 280” wheelbase and fifth wheel one notch forward of the dead center.","replyToPid":0}
发表于 2020-12-15 11:37:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Also with APU you are allowed to gross 80,500#","replyToPid":0}
 楼主| 发表于 2020-12-16 01:38:01 来自手机 | 显示全部楼层
","text":"Thank You, I didn’t know that (it say 13.200)","replyToPid":410857}
 楼主| 发表于 2020-12-16 01:40:08 来自手机 | 显示全部楼层
936953 发表于 2020-12-14 19:07:14 I should have added to check the weight limit on your tires to make sure they are also rated for at least your axle limit.
","text":"How can I check weight limit on tires?","replyToPid":410858}
 楼主| 发表于 2020-12-16 02:40:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"How can I check weight limit on tires?\n\nOkay I figured out, My Bridgestone 284 tires are 14 ply (up to 6150 pound load pressure), I will have to change the front tires in the future to 16 ply (up to 6610 - 7160 pounds load pressure)\n\nTHANK YOU ","replyToPid":0}
GMT+8, 2026-4-17 21:44 , Processed in 0.083676 second(s), 24 queries .
