查看: 123|回复: 8
Peter ride Bilt to glide🤳🏿
 楼主| 发表于 2020-12-11 17:44:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"No stalling, just hauling..","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":626.0,\"name\":\"\",\"url\":\"\",\"width\":834.0}]","canComment":true,"externalShare":false}
发表于 2020-12-11 22:43:37 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"what is that hose? Your dietary supplements? sewage drain? what!"}
发表于 2020-12-11 21:12:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ride with pride👍🇺🇸","replyToPid":0}
发表于 2020-12-15 21:56:34 来自手机 | 显示全部楼层
{"replyToPid":410873,"replyTo":"
496497 发表于 2020-12-15 01:06:15 One day I will become a true trucker when I get the opportunity to haul bulls! Love seeing those trailers lit up, with the extension on the high side in the corner pocket! Along with a big mouth radio 4-10?
","text":"🐂💪🇺🇸👍 “4 on that!”"}
发表于 2020-12-12 04:47:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes, I've done that too.","replyToPid":0}
 楼主| 发表于 2020-12-15 09:03:55 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Question, I have 8” straight stacks no muffler. What’s the best/recommend idle RPM for 10-12 hours? I was told above 8,000-9,000 to keep the wind pipes clear to reduce smoke when I first get back into the gear box.. any information is welcome. Thanks "}
 楼主| 发表于 2020-12-15 09:05:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes sir! Only way to ensure best odds of making it home is by “Doing It RiGHT” 10-FOE?!","replyToPid":410368}
 楼主| 发表于 2020-12-15 09:06:15 来自手机 | 显示全部楼层
1041283 发表于 2020-12-11 13:12:24 Ride with pride👍🇺🇸
","text":"One day I will become a true trucker when I get the opportunity to haul bulls! Love seeing those trailers lit up, with the extension on the high side in the corner pocket! Along with a big mouth radio 4-10?","replyToPid":410365}
 楼主| 发表于 2020-12-15 09:08:58 来自手机 | 显示全部楼层
1050148 发表于 2020-12-11 14:43:37 what is that hose? Your dietary supplements? sewage drain? what!
","text":"“Damnit Boi” 😂 none of the above.. Just some none hazmat plastic pellets, RawJa!?","replyToPid":410378}
GMT+8, 2026-2-9 06:23 , Processed in 0.062826 second(s), 24 queries .
