查看: 336|回复: 19
passing courtesy
 楼主| 发表于 2020-12-7 11:26:49 来自手机 | 显示全部楼层 |阅读模式
{"text":"whatever happened to the courtesy of dimming your lights when you get past to let the truck know you're clear","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-12-7 14:43:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m not your daddy, if you can’t figure out how to pass get off the road.","replyToPid":0}
回复 支持 3 反对 3
发表于 2020-12-7 18:32:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why it gotta foreigners? Why can’t it be some drivers just ain’t got courtesy period! ","replyToPid":0}
回复 支持 2 反对 4
发表于 2020-12-7 11:45:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"I just started training and my trainer told me to always do it. And he does it as well. We're on our way to Cali.","replyToPid":0}
发表于 2020-12-8 06:33:33 来自手机 | 显示全部楼层
438324 发表于 2020-12-07 22:27:55 wow what a attitude your the same guy that won't check up to let someone get by you either im sure
","text":"ABSOLUTELY WRONG, if I’m going 70 and you want go 70.5 and try and pass. I’ll gladly back out for 15 seconds to let you bye. I don’t want your dumbazz riding next me for 39 miles!!","replyToPid":409651}
回复 支持 4 反对 1
发表于 2020-12-7 11:32:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Them days are over these steering wheel holders have no courtesy","replyToPid":0}
发表于 2020-12-8 07:48:16 来自手机 | 显示全部楼层
1040831 发表于 2020-12-07 12:00:59 Sorry, I meant foreigners AND blacks. Didn’t mean to exclude you, Leroy.
","text":"F^ck you ","replyToPid":409569}
回复 支持 0 反对 4
发表于 2020-12-7 22:59:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm going 68 and you're going 75 and I have to tell you you're clear?","replyToPid":0}
回复 支持 2 反对 2
发表于 2020-12-8 10:30:10 来自手机 | 显示全部楼层
612935 发表于 2020-12-08 02:18:39 What are you? R^cist p^nk a$$
","text":"Jungle bunny","replyToPid":409710}
回复 支持 2 反对 2
发表于 2020-12-10 12:06:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"most drivers nowadays are towelheads who got their cdl from a backwash company who paid their way in. cant read English or understand how it works out here","replyToPid":0}
发表于 2020-12-7 12:00:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"always do it, 23y/o, for some reason our flash to pass and marker cut out are disabled on our trucks so I hit my lights manually and flashers, safety and common courtesy, aint so common anymore","replyToPid":0}
发表于 2020-12-8 06:27:55 来自手机 | 显示全部楼层
936953 发表于 2020-12-07 06:43:45 I’m not your daddy, if you can’t figure out how to pass get off the road.
","text":"wow what a attitude your the same guy that won't check up to let someone get by you either im sure","replyToPid":409561}
发表于 2020-12-8 07:30:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"I always flash my lights to help a driver pass.... what I can't stand is the 9 billion candlepower light bar and the high beams for no reason.....","replyToPid":0}
GMT+8, 2026-2-11 15:48 , Processed in 0.067559 second(s), 24 queries .
