查看: 279|回复: 11
Astatic or Road King mic?
 楼主| 发表于 2020-12-6 09:01:36 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have a Uniden BC 980SSB and the stock mic isn't the best. What is a good mic to pair with this radio?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-12-6 09:08:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Astatic is tried and true. They’ve been making some of the best microphones in the industry for decades. I’ve been using them for 25+ years","replyToPid":0}
发表于 2020-12-6 09:31:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"If your radio is bone stock, definitely. If you’ve taken your radio in to someone and had the power and modulation peaked out then you skip the amplified mic. If you order an amplified make sure you order a battery too, it probably won’t come with one. Some of them can take a funky battery ","replyToPid":0}
 楼主| 发表于 2020-12-6 09:10:30 来自手机 | 显示全部楼层
936953 发表于 2020-12-06 01:08:11 Astatic is tried and true. They’ve been making some of the best microphones in the industry for decades. I’ve been using them for 25+ years
","text":"I was looking online at Astatic amplified mics. Is amplified the way to go?","replyToPid":409395}
发表于 2020-12-7 00:14:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"neither d104 best one","replyToPid":0}
发表于 2020-12-6 23:04:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Road king used to be top shelf until Barjan bought the company and turned it to crap probably 10 years ago. \ndefinitely Astatic","replyToPid":0}
发表于 2020-12-7 09:01:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you have a bear cat radio, the mic plug is different, it’s not the usual 6 pin plug. ","replyToPid":0}
发表于 2020-12-7 02:38:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Astatic is the better of the 2. Road king use to be but now they are not so good","replyToPid":0}
发表于 2020-12-8 10:59:24 来自手机 | 显示全部楼层
598346 发表于 2020-12-07 23:52:37 Yes, this is true. The radio came with an adapter to accept both 4 and 6 pin mics.
","text":"Oh ok, I’ve never owned one, knew the plug was different. I’ve always used an Astatic mic, I’ve got a galaxy radio, it works great with it. ","replyToPid":409677}
 楼主| 发表于 2020-12-6 09:33:38 来自手机 | 显示全部楼层
936953 发表于 2020-12-06 01:31:57 If your radio is bone stock, definitely. If you’ve taken your radio in to someone and had the power and modulation peaked out then you skip the amplified mic. If you order an amplified make sure you order a battery too, it probably won’t come with one. Some of them can take a funky battery
","text":"Awesome! Thank you for the info. Safe travels","replyToPid":409402}
 楼主| 发表于 2020-12-7 07:56:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ha!","replyToPid":409459}
GMT+8, 2026-3-21 02:08 , Processed in 0.088182 second(s), 24 queries .
