查看: 397|回复: 8
Sliding the tandem
 楼主| 发表于 2020-12-6 01:45:26 来自手机 | 显示全部楼层 |阅读模式
{"text":"So do we count all the holes from left to right or just the ones after the stopper? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-12-6 03:53:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"still wet behind the ears I see lol","replyToPid":0}
发表于 2020-12-6 06:00:30 来自手机 | 显示全部楼层
669593 发表于 2020-12-05 18:24:08 You count the Stop hole as the 1st one and most time as kind as you in between the 5th and the 7th hole your ok nationwide with weight and you know Cali is 42 from the kingpin to the middle of the 1st rear axle
","text":"CA is 40’ to the center of the rear axle","replyToPid":409316}
发表于 2020-12-6 02:24:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"You count the Stop hole as the 1st one and most time as kind as you in between the 5th and the 7th hole your ok nationwide with weight and you know Cali is 42 from the kingpin to the middle of the 1st rear axle ","replyToPid":0}
发表于 2020-12-6 02:42:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"screw California. Texas is wide open as long as your weights are ok","replyToPid":0}
发表于 2020-12-7 10:45:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"You count the holes that you can use, stopper is not counted.","replyToPid":0}
发表于 2020-12-7 00:32:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"it doesn't matter...just the distance does .. use trucker's slide calculator","replyToPid":0}
发表于 2020-12-7 23:08:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"how are you even driving?","replyToPid":0}
 楼主| 发表于 2020-12-30 22:40:04 来自手机 | 显示全部楼层
887767 发表于 2020-12-05 19:53:50 still wet behind the ears I see lol
","text":"Lol! We have to learn some how. I got it now though. I have that baby balanced to the notch! ","replyToPid":409336}
GMT+8, 2026-4-16 12:25 , Processed in 0.135733 second(s), 24 queries .
