查看: 126|回复: 4
Speakers for 2018 Pete 579?
 楼主| 发表于 2020-12-6 00:03:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"Trying to dig up specs on audio speakers for the above but can't find so far. Current speaks might as well be dentist drills inserted into my ears. need to replace ASAP! I could pull panels but I don't want to pull, replace pull, replace; just want find the sizes info, get new speaks THEN pull, replace spks, replace panels, be done.Anybody got the info? Much appreciated! Drive safe, stay well.\nTomBow","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-12-6 00:45:33 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"There’s more than one sound system they use. If you have the little tweeters above the doors that’s the premium sound with the amp under the bunk. Just call any dealer give them the last 6 digits of the VIN, tell them you need a speaker. Get the part number and ask the dimensions."}
 楼主| 发表于 2020-12-6 03:37:36 来自手机 | 显示全部楼层
936953 发表于 2020-12-05 16:45:33 There’s more than one sound system they use. If you have the little tweeters above the doors that’s the premium sound with the amp under the bunk. Just call any dealer give them the last 6 digits of the VIN, tell them you need a speaker. Get the part number and ask the dimensions.
","text":"Thanks Man. That's the most helpful info I have found in 2 days.","replyToPid":409308}
 楼主| 发表于 2020-12-6 03:38:35 来自手机 | 显示全部楼层
","text":"Premium sound?? I'd hate to hear non-Premium.","replyToPid":409308}
 楼主| 发表于 2020-12-7 19:42:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"I checked for an amp but ain't no.I think it must be the Interegator system. 5 minutes of this torture and you'll talk!","replyToPid":0}
GMT+8, 2026-4-16 19:11 , Processed in 0.079440 second(s), 23 queries .
