查看: 187|回复: 7
How do I add a stop as a truck driver?
 楼主| 发表于 2020-12-5 09:35:22 来自手机 | 显示全部楼层 |阅读模式
{"text":"There is this diner with truck parking, it's a little off the 35 near Ardmore and they have amazing burgers, and a big lot that they let trucks overnight in.  \n\nNorman's grill isn't in the app and I'd like to add it and rate 5 stars, but I don't see how.   The add stop function doesn't list other or independent in the menu.\n\n","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true,"externalShare":false}
发表于 2020-12-6 00:12:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"keep it to yourself so none of these slobs come in and screw it up for you.","replyToPid":0}
发表于 2020-12-5 10:05:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Go to the map, select the white bar with ‘places’ in it. Upper right corner will then have ‘add a place’. Fill out the info....parking or truck stop would probably be the best category depending on hours, etc. Once you select the category you can enter the address and other info","replyToPid":0}
发表于 2020-12-5 10:02:25 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"."}
发表于 2020-12-5 23:37:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Click on “me” on bottom right scroll down to “add new places”","replyToPid":0}
发表于 2020-12-6 02:44:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"yum.","replyToPid":0}
发表于 2020-12-6 03:17:40 来自手机 | 显示全部楼层
737182 发表于 2020-12-05 16:12:14 keep it to yourself so none of these slobs come in and screw it up for you.
","text":"ABSOLUTELY!!!","replyToPid":409305}
发表于 2020-12-6 21:53:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"looks a lil light on the rings","replyToPid":0}
GMT+8, 2026-2-9 07:54 , Processed in 0.071500 second(s), 24 queries .
