查看: 261|回复: 11
Suggestions on CRST as a company to work for
 楼主| 发表于 2020-12-5 03:12:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"I am thinking of joining CRST as a driver on a dedicated run. Just wanted to check how the company is and is it worth joining them. Ps pay is not an issues. Wanna get to know more about their trucks and management ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-12-6 05:18:08 来自手机 | 显示全部楼层
737182 发表于 2020-12-05 16:16:16 clearly you're not the smartest person if it took you 9 years to figure out if a company was good or bad.
","text":"I worked for them nine years ago, not the same thing as working there nine years. Reading comprehension is a large part of our job, please do better","replyToPid":409307}
发表于 2020-12-6 00:16:16 来自手机 | 显示全部楼层
753289 发表于 2020-12-04 20:40:54 Good thing pay is not an issue, because you will practically work for free. They are a terrible company, worked for them 9 years ago. I talk to their drivers every once in a while and it seems the same. I'm not sure if you'll hear anything from one of their drivers, they probably can't afford a smartphone.
","text":"clearly you're not the smartest person if it took you 9 years to figure out if a company was good or bad.","replyToPid":409201}
回复 支持 0 反对 4
 楼主| 发表于 2020-12-5 14:56:46 来自手机 | 显示全部楼层
1040831 发表于 2020-12-04 21:51:38 CRST is a good company....for me to poop on!!
","text":"Lol","replyToPid":409213}
发表于 2020-12-6 18:00:55 来自手机 | 显示全部楼层
","text":"🤣","replyToPid":409307}
发表于 2020-12-5 06:31:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"no","replyToPid":0}
发表于 2020-12-5 05:46:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Run","replyToPid":0}
发表于 2020-12-7 00:30:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"RUNAWAY FAST AS YOU CAN !!!","replyToPid":0}
 楼主| 发表于 2020-12-5 14:56:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"👍🏃🏼‍♂️","replyToPid":409211}
 楼主| 发表于 2020-12-5 14:56:00 来自手机 | 显示全部楼层
","text":"Ok thanks for the reply I will keep that in mind ","replyToPid":409201}
发表于 2020-12-5 06:27:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"don't do it","replyToPid":0}
发表于 2020-12-5 04:40:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good thing pay is not an issue, because you will practically work for free. They are a terrible company, worked for them 9 years ago. I talk to their drivers every once in a while and it seems the same. I'm not sure if you'll hear anything from one of their drivers, they probably can't afford a smartphone.","replyToPid":0}
GMT+8, 2026-2-11 15:44 , Processed in 0.074592 second(s), 24 queries .
