查看: 427|回复: 5
Fuse help
 楼主| 发表于 2020-11-30 08:31:03 来自手机 | 显示全部楼层 |阅读模式
{"text":"Please help me to find(2019 kenworth t680) refrigerated fuse on this crazy map ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1102.0,\"name\":\"\",\"url\":\"\",\"width\":826.0}]","canComment":true,"externalShare":false}
禁止发言
发表于 2020-11-30 21:57:37 来自手机 | 显示全部楼层
发表于 2020-11-30 21:11:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"get a test light or vohm and just check them all. I dont see an obvious fuse. also its possible it's in a bunk pdm.","replyToPid":0}
发表于 2020-12-1 01:07:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"If it’s a refrigerator in the sleeper it’s most likely in the fuse box under the bunk. There’s also a fuse box under the hood.","replyToPid":0}
发表于 2020-12-2 17:19:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yep can’t read the picture when you enlarge it anyway so check bunk","replyToPid":0}
发表于 2020-12-2 17:19:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yep can’t read the picture when you enlarge it anyway so check bunk ","replyToPid":0}
GMT+8, 2026-3-21 06:10 , Processed in 0.104884 second(s), 24 queries .
