查看: 331|回复: 5
Volvo 2015 ABS&TCS lights on
 楼主| 发表于 2020-11-28 04:38:53 来自手机 | 显示全部楼层 |阅读模式
{"text":"After driving few hours both ABS & TCS lights came on , is it safe to driver or do i have pull over immediately???","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
1万
发表于 2020-11-28 23:00:29 来自手机 | 显示全部楼层
719558 发表于 2020-11-27 20:45:04 as long as you have brakes and air pressure youl be fine to make it somewhere to get checked
","text":"get used to it, trucking in 2020 and beyond... to many things to go wrong, way to much electronic crap on the new trucks...","replyToPid":408349}
回复 支持 6 反对 0
发表于 2020-11-28 05:40:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"get out and run very dangerous","replyToPid":0}
发表于 2020-11-29 23:01:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"keep on driving","replyToPid":0}
发表于 2020-11-28 04:45:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"as long as you have brakes and air pressure youl be fine to make it somewhere to get checked","replyToPid":0}
发表于 2020-11-28 10:41:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Possibly will go away next time you shut the truck off. If it comes back then it’s an actual issue. No need to stop driving. Even if you were to get a level 1 inspection the lights would most likely reset when you turn the truck off. So during the inspection it would be a pass. Just get it fixed when you can","replyToPid":0}
GMT+8, 2026-4-16 12:24 , Processed in 0.085219 second(s), 24 queries .
