查看: 348|回复: 6
ELD questions
 楼主| 发表于 2020-11-27 23:43:22 来自手机 | 显示全部楼层 |阅读模式
{"text":"yesterday I drove two five hour hitches with a half hour in between and my keep truckin eld is giving me an eleven hour warning. What?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-11-28 00:09:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not sure what a hitch is but if you’re within an hour of being out of hours  there’s usually a warning.","replyToPid":0}
发表于 2020-11-28 01:36:22 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"update your app. if you drove two five-hour sessions off of a 10 hour break, you're fine. if you drove off of split hour, that could be why you're getting HOS violation.\n\nand it always gives you 1 hour warning before 11 hours."}
发表于 2020-12-1 10:52:57 来自手机 | 显示全部楼层
69284 发表于 2020-12-01 02:22:31 you have 7and 3 or a 8and 2 for split sleeper they did not implement the 5and 5 rule.
","text":"No part of this post mentioned a split sleeper. He drove 5 hours took 30 minute brake and drove another 5 hours. Which put him within 1 hour of being out of hours. ","replyToPid":408576}
发表于 2020-12-2 07:38:22 来自手机 | 显示全部楼层
936953 发表于 2020-12-01 02:52:57 No part of this post mentioned a split sleeper. He drove 5 hours took 30 minute brake and drove another 5 hours. Which put him within 1 hour of being out of hours.
","text":"I understand that . By the what he was saying I thought he was thinking something different.  that is why I put what I put .","replyToPid":408594}
发表于 2020-11-28 03:07:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Keep Truckin gives you a ‘violation alert’ when you have 1:01 left on your 11 or 14 hr clock. It’s to let you know you’ll need to park soon","replyToPid":0}
发表于 2020-12-1 10:22:31 来自手机 | 显示全部楼层
936953 发表于 2020-11-27 16:09:58 Not sure what a hitch is but if you’re within an hour of being out of hours  there’s usually a warning.
","text":"you have 7and 3 or a 8and 2 for split sleeper they did not implement the 5and 5 rule.","replyToPid":408336}
GMT+8, 2026-4-16 12:24 , Processed in 0.121825 second(s), 25 queries .
