查看: 149|回复: 5
Basics, Need wifi to run TP?
 楼主| 发表于 2020-11-27 01:34:18 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hey there, hope your travels go well! Just figuring out which way to go for nav, to go along with the atlas. Seems, from reviews that there is good and bad experiences with all Hardware and apps available to nav with. ?--do you need wifi or mobile data to use the app on the road? Just learning the app, thought about a Garmin but if I can nav with phone, why spend the $$$? Thanks","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-11-27 03:40:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"use google maps with satellite view and recheck with atlas. dont waste the money.","replyToPid":0}
禁止发言
发表于 2020-11-27 04:51:10 来自手机 | 显示全部楼层
发表于 2020-11-27 23:05:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"get a Garmin,  hook it to your cell phone thru Bluetooth and it will give you advance notice of construction,  traffic,  and accidents.","replyToPid":0}
发表于 2020-11-27 07:51:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Google maps is for cars. It does not know the semi truck rules. I recommend getting a garmin and an atlas. Trucker path app is ok but I have had good results with my garmin 570. It helps with the traffic.","replyToPid":0}
发表于 2020-11-28 22:14:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use truckers path with the navigation added. Seems to do ok. Still use the motor carriers atlas and never hurts to call shipper/receiver for directions","replyToPid":0}
GMT+8, 2026-2-5 04:04 , Processed in 0.106220 second(s), 24 queries .
