查看: 388|回复: 6
Hello drivers, what do you do when the dock hook 🪝 that holds trailer is stuck there.
 楼主| 发表于 2020-11-24 02:07:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’m having little issue this morning . I backed into a dock and when they loaded me, the hook didn’t release, they did lots of things. I backed more as well. So I’m stuck here until they fix that. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2020-11-24 04:16:14 来自手机 | 显示全部楼层
936953 发表于 2020-11-23 18:41:55 Usually you can take a load bar or piece of wood and push it down. Someone needs to push it down while you pull forward past it.
","text":"Thanks they cut the bar already ","replyToPid":407767}
回复 支持 1 反对 4
发表于 2020-11-24 05:23:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Leave your trailer there 😂","replyToPid":0}
发表于 2020-11-25 00:37:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"riot, loot ,and burn 🔥 the building to the ground ...","replyToPid":0}
发表于 2020-11-24 05:47:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Put it in granny low and give it some gas it will detach ","replyToPid":0}
发表于 2020-11-24 02:13:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"it depends. how September 11thy is your name?","replyToPid":0}
发表于 2020-11-24 02:41:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Usually you can take a load bar or piece of wood and push it down. Someone needs to push it down while you pull forward past it.","replyToPid":0}
GMT+8, 2026-2-7 06:05 , Processed in 0.084712 second(s), 24 queries .
