查看: 257|回复: 4
Rest areas
 楼主| 发表于 2020-11-22 11:04:46 来自手机 | 显示全部楼层 |阅读模式
{"text":"How come rest areas & truckstops no longer show up on trucker path?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-11-22 11:42:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"because you unchecked it...","replyToPid":0}
 楼主| 发表于 2020-11-22 21:34:18 来自手机 | 显示全部楼层
936953 发表于 2020-11-22 05:19:53 Click places on bottom left l, then places on the right with the dot. Then select what you want in the map
","text":"Got it, thank you!","replyToPid":407601}
发表于 2020-11-22 13:19:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Click places on bottom left l, then places on the right with the dot. Then select what you want in the map","replyToPid":0}
 楼主| 发表于 2020-11-22 21:34:00 来自手机 | 显示全部楼层
1038659 发表于 2020-11-22 03:42:30 because you unchecked it...
","text":"Interesting, I must’ve done it by mistake…","replyToPid":407595}
GMT+8, 2026-4-18 01:03 , Processed in 0.316569 second(s), 24 queries .
