查看: 98|回复: 3
Chain holder/ bracket instalation
 楼主| 发表于 2020-11-19 07:25:34 来自手机 | 显示全部楼层 |阅读模式
{"text":"Has anyone ever mounted one of those snow chain brackets/ holders behind the cab? Do you just drill into the frame? and if so, do you have to use any special bolts type/grade?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-11-19 08:01:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"post some pictures. I have never seen chains mounted on the cab, chains are heavy. The wall is hollow like a double sided drywall. I can't imagine it holding 50lbs of chains.","replyToPid":0}
发表于 2020-11-19 10:49:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Shouldn’t need to drill the frame. It will utilize existing bolt holes or come with “U” style mounts that wrap around the frame.","replyToPid":0}
 楼主| 发表于 2020-11-19 08:36:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"I said behind the cab. Meaning frame rail behind the cab","replyToPid":0}
GMT+8, 2026-2-9 11:15 , Processed in 0.055652 second(s), 24 queries .
