查看: 214|回复: 7
Water bowls
 楼主| 发表于 2020-11-17 10:23:52 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’m getting a dog in a couple weeks. I’ve been looking at no-spill, skid proof types. Just wondering if anyone had any bowls that they’d  recommend?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-11-17 10:31:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"think about this long and hard before you subject an animal to your service for companionship. 😭","replyToPid":0}
回复 支持 3 反对 5
发表于 2020-11-17 20:58:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Buddy bowl is the best I ever found. If you get the 64 oz it’s heavy enough it won’t slide in the truck. ","replyToPid":0}
发表于 2020-11-17 21:19:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"I also bought a Buddy bowl and it works great. I would also recommend training them to use pee pads, will help keep your truck cleaner.","replyToPid":0}
发表于 2020-11-18 01:09:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"water b0ng better than bowls","replyToPid":0}
 楼主| 发表于 2020-11-18 03:01:16 来自手机 | 显示全部楼层
644688 发表于 2020-11-17 12:58:41 Buddy bowl is the best I ever found. If you get the 64 oz it’s heavy enough it won’t slide in the truck.
","text":"Thanks for the input, just ordered one ","replyToPid":407048}
 楼主| 发表于 2020-11-18 03:02:39 来自手机 | 显示全部楼层
925557 发表于 2020-11-17 13:19:36 I also bought a Buddy bowl and it works great. I would also recommend training them to use pee pads, will help keep your truck cleaner.
","text":"Was planning on getting pee pads as well. Don’t want pee just flowing all over the place","replyToPid":407049}
 楼主| 发表于 2020-11-18 04:57:40 来自手机 | 显示全部楼层
1039717 发表于 2020-11-17 17:09:05 water b0ng better than bowls
","text":"Don’t want my dog getting high, I’ve seen what it does to pups. My brother had a friend watch one of his dogs a while ago. She got ahold of a little bit of a joint an it effed her up for over a month","replyToPid":407065}
GMT+8, 2026-3-21 02:01 , Processed in 0.094262 second(s), 24 queries .
