查看: 878|回复: 25
 楼主| 发表于 2020-11-17 09:58:14 来自手机 | 显示全部楼层 |阅读模式
发表于 2020-11-17 10:02:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Stay off drugs","replyToPid":0}
回复 支持 8 反对 3
发表于 2020-11-17 10:17:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"I gave my dogs hair","replyToPid":0}
回复 支持 2 反对 2
 楼主| 发表于 2020-11-17 10:03:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"not on drugs smart guy","replyToPid":0}
回复 支持 2 反对 2
发表于 2020-11-17 10:27:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Did they say what you tested positive for?  I know a guy who tested positive and the offending substance was in a prescription drug he took ","replyToPid":0}
发表于 2020-11-17 10:26:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"There is a process in which you have to complete a dot approved rehab. Here is some helpful information https://www.truckingtruth.com/trucking_blogs/Article-3833/what-happens-if-i-fail-a-dot-drug-test ","replyToPid":0}
发表于 2020-11-17 10:50:55 来自手机 | 显示全部楼层
925557 发表于 2020-11-17 02:39:49 At this point I would consult an attorney.
","text":"For what? He’s the one that did drugs. Then went and took a drug test. Maybe to sue himself?","replyToPid":407004}
发表于 2020-11-17 10:12:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"millions of other jobs","replyToPid":0}
发表于 2020-11-17 12:05:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"You’re not legally able to drive regardless of who hires you until you complete the dot approved rehab program at your expense ","replyToPid":407018}
发表于 2020-11-17 19:51:35 来自手机 | 显示全部楼层
962669 发表于 2020-11-17 02:30:21 marijuana. but my urine test was clean
","text":"Most likely the reason why your urine was clean is because hair follicles store the compounds from drugs for a longer period. Do you take any sleeping pills?  Asking because some contain CBN which is a chemical found in marijuana.  The worrying part of all this is that, having talked to people who do this for a living, there are no drug tests that are 100% accurate. That’s why when they get a positive result they retest the second sample in a urine test to make sure. There are any number of reasons why you could get a false-positive result. ","replyToPid":406995}
发表于 2020-11-17 10:39:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"At this point I would consult an attorney.","replyToPid":0}
 楼主| 发表于 2020-11-17 10:30:21 来自手机 | 显示全部楼层
731716 发表于 2020-11-17 02:27:04 Did they say what you tested positive for?  I know a guy who tested positive and the offending substance was in a prescription drug he took
","text":"marijuana. but my urine test was clean","replyToPid":406992}
 楼主| 发表于 2020-11-17 10:31:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"how look does something like this stay on my record?","replyToPid":0}
发表于 2020-11-17 10:37:33 来自手机 | 显示全部楼层
962669 发表于 2020-11-17 02:31:49 how look does something like this stay on my record?
","text":"3 years","replyToPid":406997}
GMT+8, 2026-4-16 12:25 , Processed in 0.090916 second(s), 24 queries .
