查看: 322|回复: 6
Ok drivers, I have question. Can you turn off your truck if regeneration is in progress ? For morning to do it.
 楼主| 发表于 2020-11-16 09:40:05 来自手机 | 显示全部楼层 |阅读模式
 楼主| 发表于 2020-11-16 21:52:43 来自手机 | 显示全部楼层
923886 发表于 2020-11-16 06:20:56 Turning it off during regen will not hurt it. But yes depending on the make and model it may not let you in the morning. However, if it doesn't let you, it means it doesn't need it. My truck for instance (2019 international) hardly ever needs a regen. Only if I've been idling for about 12 hours. Otherwise if the regen needed light has just come on, I just have to drive for a little for it to no longer be needed.\nYour truck will not regen while driving (at least not freightliner or international), and will stop the regen as soon as you put it in drive (or touch the brakes in my truck).\nIf you're done for the night and don't like the temp outside, let her run and start the regen. It'll finish in your sleep.
","text":"I don’t run her , I got apu. And btw my truck is Volvo . And it doesn’t do regen when it parked, it has automatic regen when moving ","replyToPid":406897}
回复 支持 1 反对 3
发表于 2020-11-16 14:20:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Turning it off during regen will not hurt it. But yes depending on the make and model it may not let you in the morning. However, if it doesn't let you, it means it doesn't need it. My truck for instance (2019 international) hardly ever needs a regen. Only if I've been idling for about 12 hours. Otherwise if the regen needed light has just come on, I just have to drive for a little for it to no longer be needed.\nYour truck will not regen while driving (at least not freightliner or international), and will stop the regen as soon as you put it in drive (or touch the brakes in my truck).\nIf you're done for the night and don't like the temp outside, let her run and start the regen. It'll finish in your sleep.","replyToPid":0}
发表于 2020-11-16 09:55:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would wait for it to finish doing a Regen. You can shut it off, but depending on the make, it might not let you Regen in the morning.","replyToPid":0}
发表于 2020-11-16 12:09:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"When you stop and park it will not continue with the regen anyway. It will for a few minutes in but the will kick out. So if you’re done for the night and parked shut her down.","replyToPid":0}
发表于 2020-11-18 00:03:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"not recommended","replyToPid":0}
发表于 2020-11-18 00:49:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes shut it off during regen","replyToPid":0}
GMT+8, 2026-2-7 08:46 , Processed in 0.073406 second(s), 24 queries .
