查看: 141|回复: 2
When you thought you found a nice spot to sleep at the shipper....
 楼主| 发表于 2020-11-13 08:56:14 来自手机 | 显示全部楼层 |阅读模式
{"text":"Then you find out all the reffer units are set to continuous run 😳","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-11-13 10:06:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"shut em all off, then sleep tight!","replyToPid":0}
发表于 2020-11-13 09:10:28 来自手机
{"replyTo":"","text":"Sh.it I know guys who will run the unit on a dry load just to sleep 😂 ","replyToPid":0}
支持 1 反对 0
发表于 2020-11-13 12:54:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"I run mine on continuous, easier to sleep. ","replyToPid":0}
GMT+8, 2026-2-9 12:49 , Processed in 0.069293 second(s), 24 queries .
