查看: 379|回复: 8
Sleeping at the shipper
 楼主| 发表于 2020-11-11 08:38:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"Guy at shipper bangs on my door becuase my curtains are drawn...\"Hey! You cant spend the night here!\"\n\nMe   \"You should have thought about that before you made me sit on a dock over 5 hours and made me run out of my 14\"\n\nI am more afraid of running afoul of the DOT (and I am probably an hour from the nearest truckstop) than I am of some rent-a-cop.\n\nOh well...I went in and told them at least 4 times...and they STILL havent started loading me. I will make sure I get every minute of my 10 hour break for detention, too. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-11-11 11:10:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"The place I was at the other day left me 8 hours in the door and it turned green so I knocked on the door (no drivers inside place) and the guy ran out past me without even a hello. So I called the main building and my receiving area shut down for 4 more hours. They unloaded me and were going to make me wait four more hours just to hand me paperwork! It was done! I was the only truck left. They found a supervisor to sign off. These places are crazy! ","replyToPid":0}
回复 支持 5 反对 2
发表于 2020-11-11 16:00:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"if they regulate us drivers then they need to regulate every other aspect of the business right along with us","replyToPid":0}
回复 支持 6 反对 0
 楼主| 发表于 2020-11-11 16:22:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"They just finished...14 hours to load 19k pounds...When I get back, I am going to tell my dispatcher I will never come back here...I dont care what they do. I will get fired before coming back...I will have another job Monday.","replyToPid":0}
发表于 2020-11-11 23:17:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"some shipping and receiving need to be  executed","replyToPid":0}
发表于 2020-11-11 20:36:33 来自手机 | 显示全部楼层
724453 发表于 2020-11-11 08:00:18 if they regulate us drivers then they need to regulate every other aspect of the business right along with us
","text":"Got that right!","replyToPid":406354}
发表于 2020-11-11 09:28:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"sounds about right. lol","replyToPid":0}
发表于 2020-11-12 05:08:19 来自手机 | 显示全部楼层
915763 发表于 2020-11-11 08:22:34 They just finished...14 hours to load 19k pounds...When I get back, I am going to tell my dispatcher I will never come back here...I dont care what they do. I will get fired before coming back...I will have another job Monday.
","text":"So let me get this straight. After 5 hours you are still waiting to be loaded, in the door, and he tells you you can't sleep there even though it took them 14 hours to load you? I would tell that bïtçh àss guard to pound salt. Come back and talk to me when I'm actually loaded.","replyToPid":406355}
发表于 2020-11-11 23:43:56 来自手机 | 显示全部楼层
","text":"Had a similar experience two weeks ago. I leave split breaks on though so my clock freezes/regains after 2-3 hours. ","replyToPid":406355}
GMT+8, 2026-2-9 12:50 , Processed in 0.099524 second(s), 24 queries .
