查看: 306|回复: 5
Safest Route Abingdon Virginia to Columbus OH
 楼主| 发表于 2020-11-10 07:34:51 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello we are driving a ten speed manual with an almost 80,000 lbs load and we almost didn’t make it this morning coming from Ohio down 77 into Tennessee through those mountains and now we have to go back up to Columbus from Virginia, does anyone know a safer route? Or if that’s the safest?? Thank you so much! ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-11-10 23:20:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"the safest route is the way you drive","replyToPid":0}
发表于 2020-11-10 09:29:28 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I81s to I40w to I640w to I75n to 71n to Columbus is 484 miles of mostly flat straight interstate.it is 139 miles longer than the direct route. You will makeup some time not gong through the mountains and US highways. Good Luck"}
 楼主| 发表于 2020-11-11 02:11:47 来自手机 | 显示全部楼层
936953 发表于 2020-11-10 01:29:28 I81s to I40w to I640w to I75n to 71n to Columbus is 484 miles of mostly flat straight interstate.it is 139 miles longer than the direct route. You will makeup some time not gong through the mountains and US highways. Good Luck
","text":"Thank you! I am just now seeing this but that’s the exact route we took this morning lol we thought that looked like the flattest way. I wouldn’t mind doing that mountain route if the construction wasn’t so bad, the super narrow roads, & with a littttleee less than 80,000 lbs is preferable. Like... 30,000 less ha! ","replyToPid":406202}
 楼主| 发表于 2020-11-11 05:55:29 来自手机 | 显示全部楼层
1034640 发表于 2020-11-10 15:20:05 the safest route is the way you drive
","text":"I mean... I feel you and all it’s just that some areas just aren’t safe period. Like where we had 80,000 pounds and we’re going down a super steep grade and it turns into a one lane with concrete bumpers on the side and it’s like a roller coaster in a 10 speed that has a hard time shifting on inclines. ","replyToPid":406239}
 楼主| 发表于 2020-11-12 22:56:56 来自手机 | 显示全部楼层
","text":"Also, thank you for actually answering my question. It’s better to hear from someone with ACTUAL experience on the road than just following navigation apps & maps. Nothing compares to real life experience. But like I said thank you for ACTUALLY answering. Some of the people here act like middle schoolers with their weird comments & attitudes. Makes me wonder how old you have to be to have CDLs in some places bc all these ppl CANT be adults with the way they’re acting. ","replyToPid":406202}
GMT+8, 2026-4-16 14:32 , Processed in 0.086842 second(s), 24 queries .
