查看: 358|回复: 9
Virginia to Kentucky
 楼主| 发表于 2020-11-10 07:31:42 来自手机 | 显示全部楼层 |阅读模式
{"text":"We are in a ten speed manual with almost 80,000 lbs. does anyone know what is the safest route from AbingdonVirginia to Columbus Ohio? We came this way down 77 & it was extremely dangerous & I really don’t think we need to go that way again. Thanks ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-11-11 12:34:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nothing in that region is dangerous SMH","replyToPid":0}
发表于 2020-11-10 08:41:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"hwy 23 to the west runs parallel but 77 is a better maintained road and choice.","replyToPid":0}
发表于 2020-11-13 01:16:50 来自手机 | 显示全部楼层
1033519 发表于 2020-11-12 14:53:31 Nobody said I was scared... all I said was IS THERE A SAFER ROUTE. Are you even reading posts or just responding?? ANYONE IN THEIR RIGHT MIND knows that it is dangerous driving on mountain roads with heavy road work going on... are you ok??
","text":"Sounds like you’re scared. Do us a favor. Take the winter off. 👌🏻 ","replyToPid":406529}
发表于 2020-11-12 11:24:08 来自手机 | 显示全部楼层
1033519 发表于 2020-11-11 20:44:41 Why are you being so rude? YES IT WAS DANGEROUS. There was hella road construction. If you don’t have a suggestion mind your business how about that??
","text":"Shu.t up stu.pid I grew up hauling cattle on the roads in that region. If you’re scared trucking isn’t for you.","replyToPid":406420}
发表于 2020-11-10 08:31:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Really no other way that doesn’t double your mileage.","replyToPid":0}
 楼主| 发表于 2020-11-12 04:44:41 来自手机 | 显示全部楼层
945974 发表于 2020-11-11 04:34:14 Nothing in that region is dangerous SMH
","text":"Why are you being so rude? YES IT WAS DANGEROUS. There was hella road construction. If you don’t have a suggestion mind your business how about that??","replyToPid":406345}
 楼主| 发表于 2020-11-12 22:53:31 来自手机 | 显示全部楼层
945974 发表于 2020-11-12 03:24:08 Shu.t up stu.pid I grew up hauling cattle on the roads in that region. If you’re scared trucking isn’t for you.
","text":"Nobody said I was scared... all I said was IS THERE A SAFER ROUTE. Are you even reading posts or just responding?? ANYONE IN THEIR RIGHT MIND knows that it is dangerous driving on mountain roads with heavy road work going on... are you ok?? ","replyToPid":406476}
 楼主| 发表于 2020-11-13 02:42:04 来自手机 | 显示全部楼层
945974 发表于 2020-11-12 17:16:50 Sounds like you’re scared. Do us a favor. Take the winter off. 👌🏻
","text":"How about YOU do US the favor and sign out or keep your negativity to yourself.... people like you are what makes this world insufferable. Snow & mountains ain’t the problem, it’s people like you. What is your point in doing they? And how old are you??? You’re less mature than most CHILDREN I know... ","replyToPid":406543}
发表于 2020-11-13 02:46:48 来自手机 | 显示全部楼层
1033519 发表于 2020-11-12 18:42:04 How about YOU do US the favor and sign out or keep your negativity to yourself.... people like you are what makes this world insufferable. Snow & mountains ain’t the problem, it’s people like you. What is your point in doing they? And how old are you??? You’re less mature than most CHILDREN I know...
","text":"I’m 40 and been driving full time 20 years. Not a mountain range I haven’t crossed. 👌🏻 ","replyToPid":406554}
GMT+8, 2026-4-16 21:22 , Processed in 0.131192 second(s), 25 queries .
