查看: 334|回复: 8
Dock door parties
 楼主| 发表于 2020-11-6 00:19:17 来自手机 | 显示全部楼层 |阅读模式
{"text":"My dock door should not look like an outdoor yard party. I should not have congregations of men milling about my truck when I am backing. I CANT SEE YOU. STOP IT. If you value your equipment more than your own life, you are not in the right kind of work. If you think I will hit your truck, don’t you think you should be afraid I will hit your body even more? Your truck can be fixed. Your body maybe not. Get away from my VEHICLE. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-11-6 03:05:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"They freak out when they see a woman backing a truck.  🙄🙄  I had an entire construction crew, on break, line up along a fence to watch me back once.  No pressure..thanks. Ugh....","replyToPid":0}
回复 支持 7 反对 2
发表于 2020-11-6 04:43:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"👍of course she can't see she's 5 ft and 190 lbs trying to back in with a hot pocket on one hand.","replyToPid":405691}
发表于 2020-11-6 00:38:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Shut up st.u.pid","replyToPid":0}
发表于 2020-11-6 02:38:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Tell um like it is girl 👧 ","replyToPid":0}
回复 支持 0 反对 3
发表于 2021-1-22 11:55:10 来自手机 | 显示全部楼层
发表于 2020-11-6 04:28:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"😂😂😂😂","replyToPid":0}
发表于 2021-1-14 15:25:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"there hanging around because your hot!","replyToPid":0}
发表于 2021-1-14 15:27:33 来自手机 | 显示全部楼层
970597 发表于 2020-11-05 19:05:04 They freak out when they see a woman backing a truck.  🙄🙄  I had an entire construction crew, on break, line up along a fence to watch me back once.  No pressure..thanks. Ugh....
","text":"no its cause your hot! and can do it too!","replyToPid":405701}
GMT+8, 2026-4-17 21:14 , Processed in 0.098229 second(s), 24 queries .
