查看: 95|回复: 0
2021 International? MV? Series
 楼主| 发表于 2020-11-5 14:01:04 来自手机 | 显示全部楼层 |阅读模式
VIN: 3HAEUMMN0ML046830
Hide Access Link: https://prd-forum-api.truckerpath.com/v6/direct_link/?actionCode=AccessTruckAndJobAction&pk=fe20302617596fe8607&token=418e97600c2860147a21ba59fc698064
mileageV2:
colorV2: White
zipcodeV2: 85043
cityV2: Phoenix
stateV2: AZ
condV2: New
emailV2: mkill@rwcgroup.com
makemodelV2: International? MV? Series
phonenoV2: 6026095599
priceV2: 00
stocknoV2: N046830
latitudeV2: 33.42
longitudeV2: -112.2
modelyearV2: 2021
LucrativId: 3737377
LocationId: 3030687
{"text":"2021 International® MV™ SeriesMaking MovesIntroducing the mv™ series,delivering uptime day in and day out.Step up your uptimeWe get drivers and their needs, and we get them where they’re going—safely and comfortably. With a wide range of applications and a focus on connectivity, the MV™ Series works to your advantage by giving you quality you can depend on—day in and day out.The superior combination of uptime, DriverFirst design and maximum cab-axle flexibility makes the MV™ Series the ultimate work truck in its class. Leaving no detail behind, International® is the leading maker of fully integrated medium-duty trucks that deliver beyond your expectations.Features may include:Advancing the science of productivityThe most advanced system in the industry for its integration and ability to allow customers to optimize their driving experience. Choose from nearly 200 pre-programmed tasks or program your own for your specific application, with connectivity innovations that make your job easier than ever.Perfect positionWith the largest cab in its class, the MV Series features intuitive, customizable and optimally positioned switches and controls. The steering-column-mounted stalk shifter enables better reach and greater legroom, with the cab’s intelligent functions placed right at the driver’s fingertips.Everything proofReady to handle whatever the road throws at you, the MV Series is a truck like no other, giving drivers the optimal quality and reliability they depend on. With the industry’s most trusted powertrain and safety features to ensure productivity, you can keep on trucking to maximize your uptime.Automatic advantagesMV Series packs an extra punch with industry-leading automatic transmissions. Choose the right fit for your specific needs, and you’ll be off and running in no time. With three different options, you can guarantee perfect delivery each and every time—no matter the driver’s experience level.Strong looksMV Series enhances side visibility with reshaped doors, side windows and repositioned cab mirrors, plus a 62-degree door swing makes room for extended step length. The HSLA reinforced, cold-rolled steel cab gives the MV™ Series the strength to tough it through anything.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0}]","canComment":null,"externalShare":false}
GMT+8, 2026-4-2 13:58 , Processed in 0.064134 second(s), 25 queries .
