查看: 306|回复: 10
Weight
 楼主| 发表于 2020-11-5 11:54:14 来自手机 | 显示全部楼层 |阅读模式
{"text":"No matter what hole I put my pins in my weight is screwed  and no my 5th wheel doesn’t move \nTandems have  holes 4 inches apart\nAnyone have any suggestions \nStr-11000\nDrvs-34460\nTnsms-32800\nTotal-79260\nShould I roll with it \nHeading to Indy from Baton Rouge ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-11-5 12:41:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"just burn 100 gallons of diesel and you will be fine","replyToPid":0}
发表于 2020-11-5 12:10:17 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Well you need to slide your tandems two holes forward, maybe three. If you’re tandems are already all the way forward there’s nothing you can do without a sliding fifth wheel. If you have an APU you have a 450 pound weight exemption on your drive axles ( not recognized in every state) other than that try to burn 65 gallons or so of fuel before you get to a scale...good luck"}
发表于 2020-11-16 11:27:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Guy's trying to get the basics dwn huh?Same mentality that votes for Hidin.","replyToPid":0}
 楼主| 发表于 2020-11-5 13:45:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"You guys are awesome tyvm and y’all be safe thanks again ","replyToPid":0}
发表于 2020-11-5 19:40:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Almost all states give 1000# per axle as long as you’re under 80k. I hit a scale in Iowa and was 34,800 and all he said was slide the tandems. ","replyToPid":0}
发表于 2020-11-5 20:31:58 来自手机 | 显示全部楼层
669771 发表于 2020-11-05 11:40:01 Almost all states give 1000# per axle as long as you’re under 80k. I hit a scale in Iowa and was 34,800 and all he said was slide the tandems.
","text":"Most states my a55, just because you got a pass doesn’t mean it’s the norm.","replyToPid":405658}
发表于 2020-11-5 21:07:06 来自手机 | 显示全部楼层
936953 发表于 2020-11-05 12:31:58 Most states my a55, just because you got a pass doesn’t mean it’s the norm.
","text":"It is the norm. Very few ticket for anything under 1000","replyToPid":405660}
发表于 2020-11-5 21:34:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"just push the reset button on the scales the grab your nuts and jump up and down","replyToPid":0}
发表于 2020-11-6 00:04:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would move the tandems 2 holes forward","replyToPid":0}
发表于 2020-11-6 22:04:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"drive at night","replyToPid":0}
GMT+8, 2026-4-18 01:02 , Processed in 0.129828 second(s), 24 queries .
