查看: 228|回复: 9
Question regarding violation.
 楼主| 发表于 2020-11-4 13:11:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello Everyone, I’m new to truck driving. Recently, i got violations from California DOT regarding break adjustment, right front tire hub seal leak and Air loss from brake chamber. So, my question is does it affect my driving record  for future ? If that so, how long does it stays on my driving record? Please advise thank you for your help.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
禁止发言
发表于 2020-11-4 13:14:59 来自手机 | 显示全部楼层
禁止发言
发表于 2020-11-4 14:04:11 来自手机 | 显示全部楼层
 楼主| 发表于 2020-11-4 13:20:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"How long does it stays on record?","replyToPid":0}
 楼主| 发表于 2020-11-4 13:20:28 来自手机 | 显示全部楼层
147103 发表于 2020-11-04 05:14:59 Yes that goes on your CSA score.  You got points for each item.
","text":"How long does it stays on record?","replyToPid":405552}
发表于 2020-11-4 13:39:06 来自手机 | 显示全部楼层
852743 发表于 2020-11-04 05:20:08 How long does it stays on record?
","text":"stays for 3 years","replyToPid":405553}
 楼主| 发表于 2020-11-4 13:41:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Does it affect driving history or if i want to change the job? Do the employer look at it?","replyToPid":405561}
发表于 2020-11-4 20:10:33 来自手机 | 显示全部楼层
","text":"Up to 5 yrs goes on your psp as well need to hire road lawyer and fight it try TVC their in a lot of truck stops they are really good with that sort of thing","replyToPid":405553}
发表于 2020-11-5 11:33:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Did you receive a warning or a citation? Warnings cannot be contested in court, but citations can. If you were cited, hire an attorney and fight it. Points on your CSA score follow you if you change employers, some will not care, others will, especially if you were placed out of service. In your case, it basically did not to thorough pre and post trip inspections, if you do nut know how to do one or adjust your brakes, find someone to teach you.","replyToPid":0}
发表于 2020-11-5 23:33:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just hire a lawyer and you good. You’ll just need to spend around $1.5-2k on hiring one and your record won’t be affected)","replyToPid":0}
GMT+8, 2026-4-18 07:12 , Processed in 0.105428 second(s), 24 queries .
