查看: 634|回复: 34
Haven’t driven in 2yrs after a small non-dot recorded accident & now I’m having a hard time getting hired. Any advice?
 楼主| 发表于 2020-11-3 04:19:11 来自手机 | 显示全部楼层 |阅读模式
{"text":"2+ years exp as company driver and Schneider, Jbhunt Crete PTI have all turned me down. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-11-3 04:39:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"shave, wipe that stu.pid grin off your face, and mature a little more. give it another 3 years and try again.","replyToPid":0}
回复 支持 1 反对 8
发表于 2020-11-3 06:24:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Swift will take anyone","replyToPid":0}
回复 支持 6 反对 1
发表于 2020-11-3 08:20:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"I find that extremely hard to believe, truck companies are so low on drivers these days, they will hire a M O N K E Y...  ","replyToPid":0}
回复 支持 5 反对 1
发表于 2020-11-3 08:44:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Western Express takes everybody..... everybody","replyToPid":0}
发表于 2020-11-3 10:48:23 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"try swift or western express!! they accept criminals straight out from jail, so you should be the cleanist driving record compared to other in the company!! Good luck"}
发表于 2020-11-3 06:27:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"accidents typically take 3 yrs to clear for u to work under the insurance guidelines.\n\nnot the company that's stopping you, it's the insurance policy they are paying for.\n\nur almost there man, try PTL-Paschall truck Lines. which u may hate, or abalone Express, or usa truck","replyToPid":0}
发表于 2020-11-3 04:55:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Did you return your equipment where it was supposed to go? Did you give notice? Were you fired? Those could be the problem. You need to see your DAC report at least. Someone might have written in something false. I had a misreported accident on mine for a while. Took me getting old employer to fix their mistake. Heck, ask the companies why they didn't hire you.","replyToPid":0}
发表于 2020-11-3 08:15:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you were inebriated or had anything illegal on you you can forget about driving.","replyToPid":0}
发表于 2020-11-3 19:46:15 来自手机 | 显示全部楼层
1032268 发表于 2020-11-02 20:39:09 shave, wipe that stu.pid grin off your face, and mature a little more. give it another 3 years and try again.
","text":"Allow it man, stop been negative \nGoddamn it ","replyToPid":405302}
发表于 2020-11-3 09:35:24 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"If you were terminated due to the “minor” accident, that’s your problem. They’re reporting you were terminated for an unsatisfactory safety record. My friend had the same problem over 10 years ago from Swift. To this day no one will  hire him. Even though is not on his driving record they still find it."}
发表于 2020-11-3 05:51:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"you need more tattoos","replyToPid":0}
GMT+8, 2026-4-17 19:08 , Processed in 0.115208 second(s), 24 queries .
