查看: 185|回复: 4
SMH
 楼主| 发表于 2020-11-2 03:22:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"While parked the other night, I was awaken by the shake we all dread. Jumped out to find this Prime  trailer lodged against my fb. I done what I needed to do to help the driver get off my trailer. Here is where I mention that the female driver, behind the wheel, never once got out the truck to see what she hit and how bad it was. This woman had the nerve to be mad at me because she couldn't maneuver to swing the front of the trailer (turn hard left and back up). Had the nerve to yell at ME and insist I need to move my truck...wt$ To speed up this process and get out the rain, I moved my rig about 10 ft forward.Can you believe that pulling forward she hit my trailer AGAIN. When I started cussing,  another female came out the back and asked \"can you just move so we can go?\" Hold the $#@% up, are you the trainer, I ask? She was. Then why in the %$#@ are you in the back while your student tears up my trailer. Mind you, the pajama clad driver still hasn't moved from the seat!!! Trainer gets out to join me in the rain and I pull my rig completely out of the way from this parking lot menace. I see their trailer move so I returned to my parking spot and get out with my info even though there is nothing you can really do with the damage. To my surprise...this female trailer killing crew leaves the parking lot and gets on the freeway🤣🤣🤣🤣🤣 Welp...the call to Prime safety was quite interesting as I explained their shenanigans. I hear him tell someone,  locate this trailer and route the drivers to the yard😎","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":908.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0},{\"description\":\"\",\"height\":908.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0},{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":908.0}]","canComment":true,"externalShare":false}
发表于 2020-12-8 01:11:32 来自手机 | 显示全部楼层
759463 发表于 2020-11-02 22:50:07 Good for you driver,  but i doubt prime will do anything about it
","text":"I'd like to be naively optimistic and believe that even a company as disreputable as Prime would have no problem re-introducing these two \"drivers\" to the unemployment line.","replyToPid":405321}
发表于 2020-11-3 06:50:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good for you driver,  but i doubt prime will do anything about it","replyToPid":0}
发表于 2021-1-15 09:14:18 来自手机 | 显示全部楼层
612134 发表于 2021-01-12 18:50:09 WOW! thats crazy! I can see clearly where they shaved off almost half of that reflective sticker! 😂
","text":"So you do these things also? You’re making lite of it, sticker.... fender..... Alfa Romero..... all the same? \n\nThat’s like saying stealing 5 cents is okay, not a problem till you hit 100 k \n\n","replyToPid":413364}
发表于 2021-1-13 02:50:09 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"WOW! thats crazy! I can see clearly where they shaved off almost half of that reflective sticker! 😂"}
GMT+8, 2026-2-11 04:59 , Processed in 0.083763 second(s), 24 queries .
