查看: 372|回复: 12
Trucker Path Map Question?
 楼主| 发表于 2020-11-1 09:16:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"How many drivers rely on the map and directions?  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-11-2 02:18:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use Google maps give me directions but I don't follow them I use it like a regular map but I could zoom in and see if that's the way I want to go always verify before you go that way because it's meant for a car","replyToPid":0}
发表于 2020-11-2 22:23:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m my opinion, trucker path maps/ gps is accurate 99% of the time. However, twice in the last 5 months, TP has tried to put me on roads that are banned to trucks. Example: in portage, NY it tried to put me on a road with a 10 ton weight limit. A fully loaded 5 axle truck is 40 ton. I got turned around. The main way to avoid trouble is to always look at your Rand McNally paper map before driving. Having the paper map image in your mind helps you to double check the gps and know when it’s lying. ","replyToPid":0}
发表于 2020-11-1 09:54:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"none of, I tried and given me wrong direction and payed for this $99.99 I canceled the service next day but no money refunded. your choice to check ✔.","replyToPid":0}
发表于 2020-11-1 21:52:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Really? Its that bad eh. Garmin or rand?","replyToPid":0}
发表于 2020-11-1 12:05:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"don't","replyToPid":0}
发表于 2020-11-2 00:41:36 来自手机 | 显示全部楼层
588837 发表于 2020-11-01 01:54:57 none of, I tried and given me wrong direction and payed for this $99.99 I canceled the service next day but no money refunded. your choice to check ✔.
","text":"Don’t trust it!! I used the free trial and it’s terrible.  ","replyToPid":405189}
发表于 2020-11-2 23:11:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Map hardly ever use gps run same roads mostly ","replyToPid":0}
发表于 2020-11-3 06:40:00 来自手机 | 显示全部楼层
","text":"I have no problems with google maps. Gets me pretty close","replyToPid":405189}
发表于 2020-11-3 12:33:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"I did the trial. hated it. paying for copilot now","replyToPid":0}
GMT+8, 2026-4-16 12:24 , Processed in 0.145731 second(s), 24 queries .
