查看: 167|回复: 3
Straps
 楼主| 发表于 2020-10-30 07:31:27 来自手机 | 显示全部楼层 |阅读模式
{"text":"What length of strap do you need to strap down a 400bbl tank on a flatbed?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-10-30 08:23:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"24’ long 13’ high 13’ wide (12’ wide if not insulated) are the dimensions for a standard 400 BBL Tank","replyToPid":0}
 楼主| 发表于 2020-10-30 10:46:12 来自手机 | 显示全部楼层
936953 发表于 2020-10-30 00:23:17 24’ long 13’ high 13’ wide (12’ wide if not insulated) are the dimensions for a standard 400 BBL Tank
","text":"I know the length of the tank. It’s 20’ tall x 12’. How long should the straps be to secure it to a flatbed if it’s laid on it’s side. 27’, 30’...?","replyToPid":405016}
发表于 2020-10-30 11:03:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well you’re looking at 12 up 12 across 12 down 2 on each side to get back to the trailer. That’s 40’ probably want 45’","replyToPid":0}
GMT+8, 2026-2-4 09:26 , Processed in 0.078091 second(s), 23 queries .
