查看: 246|回复: 5
Hello good morning, I have little isssue this morning, my trailer running lights not working but 4way lights are.
 楼主| 发表于 2020-10-28 20:18:15 来自手机 | 显示全部楼层 |阅读模式
{"text":"4way lights are the only ones working other than that my trailer lights are off . Anyone knows why? And how to fix it .","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
1万
发表于 2020-10-28 20:30:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"did you turn the light switch on ??? ok try wiggling the light cord going into the trailer and/or at the back of the cab... also you might have to pull the plug out and spread the prongs out inside the plug with a screwdriver (just a little) \nor you can wait till the sun comes up (just kidding)","replyToPid":0}
发表于 2020-10-28 23:09:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"4 ways are on a separate fuse. Start there. If fuses check out, check both ends of your cord for corrosion Everyone overlooks the plug on tractor side.","replyToPid":0}
发表于 2020-10-28 22:26:16 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"had same problem a few months back. water in an led light shorted out, check your lights for lightly deformed or discolored appearance or water"}
发表于 2020-10-28 21:16:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yupp! Check your fuses ! ","replyToPid":0}
发表于 2020-10-28 21:02:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Blown fuse. ","replyToPid":0}
GMT+8, 2026-2-7 09:50 , Processed in 0.062408 second(s), 24 queries .
