查看: 479|回复: 5
7/3-8/2 split question
 楼主| 发表于 2020-10-28 06:53:53 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’m trying to do a split sleeper birth to get to my delivery at the right time, if I do a 7/3 split after I complete my delivery and get parked do I have to take 3 off or a full 10?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-10-28 08:19:55 来自手机 | 显示全部楼层
1015506 发表于 2020-10-27 23:28:56 So if I don’t have to be anywhere urgently when I take the second break I might as well take 10? Or will I get my 14/11 after the second break of 3 hours is over? Just a little confused and don’t want to go into violation
","text":"You’ll get the difference. What ever you use after the 7 hour break let’s say 4 hours to make delivery. Once you take another 3 hour brake you will get your 11/14 minus the 4 hours you already used (minus the three hour break on your 14 too) ","replyToPid":404810}
发表于 2020-10-28 11:43:05 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Split sleeper is deceiving. Only way to start fresh is 10 off. I got a citation a couple months ago even though my ELD was not showing a violation. DOT computer caught the violation when I emailed my logs to the officer. I’ve been running a lot of reefer loads ELD exempt lately. "}
发表于 2020-10-28 07:19:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Once you do a 3 then a 7, you have to do a 10. Unless you leave some time on the clock... If so, you can do another 7/3 split. ","replyToPid":0}
 楼主| 发表于 2020-10-28 07:28:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"So if I don’t have to be anywhere urgently when I take the second break I might as well take 10? Or will I get my 14/11 after the second break of 3 hours is over? Just a little confused and don’t want to go into violation ","replyToPid":0}
 楼主| 发表于 2020-10-28 10:06:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ahh I gotcha! That makes sense, thank you!","replyToPid":0}
GMT+8, 2026-4-16 14:31 , Processed in 0.070957 second(s), 24 queries .
