查看: 328|回复: 19
truck dies
 楼主| 发表于 2020-10-27 23:25:07 来自手机 | 显示全部楼层 |阅读模式
{"text":"We're at a loss. My 97 international 9400 with cat 3406 14.6l seems to lose fuel pressure in the morning. it's been doing it for a couple weeks now. Took it to a shop and wouldn't die for them and pressure was good. I've tried letting it run and shutting it down. Will idle and start fine but when you start to move it starts losing power and chugs and dies. I've tried upping the rpms before I take off but still does it. Changed the primer but still no luck. Takes a few times priming and cranking then it runs fine all day. 🤔😵😡😠🤬🤬🤬😩🤷‍♂️","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-10-28 01:25:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"You’ve got a leak, pulling air in. I had a similar issue . Was a bad check valve. But could be just about anything. ","replyToPid":0}
发表于 2020-10-28 02:28:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Kevin Rutherfraud would recommend replacing all fuel lines. If you have not already done so.","replyToPid":0}
发表于 2020-10-28 04:25:55 来自手机 | 显示全部楼层
1028228 发表于 2020-10-27 19:25:24 yeah I'd bet on a collapsed line
","text":"It’s not a collapsed line. If it was it would always be collapsed. Once he get it running and warmed up it runs good all day. A collapsed line would always be collapsed.","replyToPid":404781}
发表于 2020-10-28 04:08:30 来自手机 | 显示全部楼层
764614 发表于 2020-10-27 20:05:46 Weird thing is it runs fine during the day and after sitting overnight back home it doesn't do it. But I'll track all my lines and ck on new ones.
","text":"Good luck dude. Get that thing up and running back in the money. ","replyToPid":404789}
禁止发言
发表于 2020-10-28 00:41:31 来自手机 | 显示全部楼层
发表于 2020-10-29 22:52:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"I had the same problems on my 99 and 07 International Put all new lines and fittings and solved the problems both times. I had them made up with hydraulic lines ","replyToPid":0}
发表于 2020-10-29 21:14:34 来自手机 | 显示全部楼层
936953 发表于 2020-10-27 17:25:43 You’ve got a leak, pulling air in. I had a similar issue . Was a bad check valve. But could be just about anything.
","text":"I was also thinking a check valve","replyToPid":404774}
 楼主| 发表于 2020-10-28 04:05:46 来自手机 | 显示全部楼层
147103 发表于 2020-10-27 16:41:31 I think you got fuel line issue. Have you checked lines to tank? I've seen the line come apart inside. Causing similar issue before
","text":"Weird thing is it runs fine during the day and after sitting overnight back home it doesn't do it. But I'll track all my lines and ck on new ones.","replyToPid":404772}
发表于 2020-10-28 00:35:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"I think you must have a small leak on the system, it might be hard to find though.","replyToPid":0}
 楼主| 发表于 2020-10-28 04:08:25 来自手机 | 显示全部楼层
945974 发表于 2020-10-27 18:28:33 Kevin Rutherfraud would recommend replacing all fuel lines. If you have not already done so.
","text":"No I haven't. Asked International for a price but was told there system shows just hose without ends. Thinking about taking them to the local hydraulic place back home and having them make some up.","replyToPid":404776}
 楼主| 发表于 2020-10-28 04:10:21 来自手机 | 显示全部楼层
945974 发表于 2020-10-27 20:08:30 Good luck dude. Get that thing up and running back in the money.
","text":"I'm still running her. Just frustrating having to find a spot to park at night knowing that it'll die as soon as I pull out of the spot.","replyToPid":404791}
GMT+8, 2026-2-9 14:31 , Processed in 0.054316 second(s), 24 queries .
