查看: 232|回复: 2
truck dies
 楼主| 发表于 2020-10-27 23:23:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"We're at a loss. My 97 international 9400 with cat 3406 14.6l seems to lose fuel pressure in the morning. it's been doing it for a couple weeks now. Took it to a shop and wouldn't die for them and pressure was good. I've tried letting it run and shutting it down. Will idle and start fine but when you start to move it starts losing power and chugs and dies. I've tried upping the rpms before I take off but still does it. Changed the primer but still no luck. Takes a few times priming and cranking then it runs fine all day. 🤔😵😡😠🤬🤬🤬😩🤷‍♂️","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-10-27 23:39:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"You got something sucking air. They’re a pain to locate. I had a similar issue with low fuel pressure when climbing hills. Turned out to be a bad check valve. ","replyToPid":0}
发表于 2020-10-27 23:40:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"You got something sucklng air. They’re a pain to locate. I had a similar issue with low fuel pressure when climbing hills. Turned out to be a bad check valve. ","replyToPid":0}
GMT+8, 2026-4-16 08:55 , Processed in 0.068356 second(s), 24 queries .
