查看: 534|回复: 14
Average miles driving
 楼主| 发表于 2020-10-27 00:53:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"How many miles can a driver run in an 11 hours??\nWhat’s the average legally??","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-10-27 01:03:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Depends on speed limit, traffic, weather, load, many variables. I've done 500 to over 700. Won't say how many with paper.","replyToPid":0}
回复 支持 7 反对 0
发表于 2020-10-27 01:28:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"650-700 is a good day 👌🏻 ","replyToPid":0}
发表于 2020-10-27 04:35:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"My personal best is 734 miles with only 5 minutes to spare. ","replyToPid":0}
发表于 2020-10-27 07:08:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"So the average raw mph in the United States is 45 mph. That includes every single bit of movement including your backing and parking. Remember that because if you are significantly over that on a regular basis the DOT could be way more interested in poking around your records. ","replyToPid":0}
发表于 2020-10-27 03:01:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"There’s no such thing as “average legally”. You drive what you drive. Log what you do and do what you log.","replyToPid":0}
发表于 2020-10-27 01:12:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Adam is right, it has a lot of variables, even what type of trailer you are pulling, a flatbed will usually avers less miles per day due to safety checks and usually heavier loads. Also depends on what part of the country you are in.","replyToPid":0}
发表于 2020-10-27 03:40:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"825 miles is my personal best. No speeding or cheating elogs.","replyToPid":0}
发表于 2020-10-27 22:46:44 来自手机 | 显示全部楼层
678033 发表于 2020-10-26 23:08:39 So the average raw mph in the United States is 45 mph. That includes every single bit of movement including your backing and parking. Remember that because if you are significantly over that on a regular basis the DOT could be way more interested in poking around your records.
","text":"BS, don’t believe everything they tell you at Swift orientation. My GPS tracks all movements and I’m consistently in the mid 60’s. You guys are hilarious.","replyToPid":404689}
发表于 2020-10-28 07:30:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"1000","replyToPid":0}
GMT+8, 2026-4-17 22:25 , Processed in 0.117755 second(s), 24 queries .
