查看: 181|回复: 6
Hey guys does the apu charge your batteries if you’re truck doesn’t start so cold weather ?
 楼主| 发表于 2020-10-23 00:14:58 来自手机 | 显示全部楼层 |阅读模式
 楼主| 发表于 2020-10-23 00:33:11 来自手机 | 显示全部楼层
939430 发表于 2020-10-22 16:26:12 Good Question I'm wondering the same thing
","text":"Update it helped charge my batteries , and started ","replyToPid":404085}
回复 支持 0 反对 3
发表于 2020-10-23 00:48:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do not turn off your APU or start your truck before you have a solid recharge. It takes some power to get started and your voltage won’t let you do it twice. ","replyToPid":0}
发表于 2020-10-23 00:47:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Im not sure the lowest voltage for the APU. So far I’ve started as low as 12.6. ","replyToPid":0}
发表于 2020-10-23 00:46:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"If my truck volts is below 13.1 it will not start. I can turn on the fan to force the APU on at a lower voltage and quick charge the batteries to get running again. I try and always keep a fan running so the APU will keep my battery charged when I’m asleep. Plus it’s white noise. Be sure to keep jumper cables though. Especially if you have a reefer some such. ","replyToPid":0}
发表于 2020-10-23 00:26:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good Question I'm wondering the same thing","replyToPid":0}
发表于 2020-10-23 02:33:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thermo King Tripac kicks on at 12.3 volts to maintain battery voltage, as long as you have the power on and engine power on. ","replyToPid":0}
GMT+8, 2026-2-7 10:05 , Processed in 0.062843 second(s), 24 queries .
