查看: 248|回复: 4
Front drive axle
 楼主| 发表于 2020-10-22 09:22:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello guys and girls does anyone knows how much it would cost me to get my front drive hooked up to pull only my back axle pulls. Thank You ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2020-10-22 09:42:44 来自手机 | 显示全部楼层
794377 发表于 2020-10-22 01:38:48 Nothing, flip the power divider switch on the dash
","text":"It doesn’t have a flip switch it’s a one axle drive ","replyToPid":404026}
发表于 2020-10-22 09:51:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"At least $10k, just changing gears in a rear end costs $5k and you don’t even have an axle. ","replyToPid":0}
 楼主| 发表于 2020-10-22 09:44:09 来自手机 | 显示全部楼层
644760 发表于 2020-10-22 01:42:44 It doesn’t have a flip switch it’s a one axle drive
","text":"It has two axles ","replyToPid":404027}
 楼主| 发表于 2020-10-22 09:53:35 来自手机 | 显示全部楼层
936953 发表于 2020-10-22 01:51:11 At least $10k, just changing gears in a rear end costs $5k and you don’t even have an axle.
","text":"Thank You ","replyToPid":404031}
GMT+8, 2026-4-17 23:49 , Processed in 0.077313 second(s), 24 queries .
