查看: 208|回复: 11
GOOD MORNING Y'ALL
 楼主| 发表于 2020-10-18 23:22:47 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'M SHOPPING FOR A NEW DRIVES TIRE\nSET OF 8!!!\nI NEED YOU'RE OPINIONS DRIVER'S ON WHAT TO GO WITH!!\nBEFORE I GET ROBBED\nTHANK YOU ALL","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-10-19 00:59:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bridgestone is a good alternative to michelin and will save you money.  Toyo are also not bad and half the price of michelin.  Unless you are swimming in money probably not worth it to wrap the whole truck in michelins.","replyToPid":0}
发表于 2020-10-19 03:05:33 来自手机 | 显示全部楼层
thank you all, I'm looking on some saving!! any ideas on 🇨🇳s tires
{"replyToPid":403661,"replyTo":"
955359 发表于 2020-10-18 18:51:04 thank you all, I'm looking on some saving!! any ideas on 🇨🇳s  tires
","text":"NEVER. Garbage."}
发表于 2020-10-18 23:39:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"I am thinking Michelin are the best should cost around 3500,I don’t know I am going get some myself.","replyToPid":0}
发表于 2020-10-19 07:12:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"You’ll hardly go wrong with either of them , \nAnd sailun ...","replyToPid":0}
发表于 2020-10-19 07:11:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hercules, Roadlux very good offshore brands ...","replyToPid":0}
发表于 2020-10-19 19:59:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"bfgoodrich isn't bad either if the Michelin price tag takes your breath away","replyToPid":0}
 楼主| 发表于 2020-10-19 02:51:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank you all, I'm looking on some saving!! any ideas on 🇨🇳s  tires","replyToPid":0}
发表于 2020-10-19 15:57:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Michelin...... or Bridgestone 🚶🏾‍♂️","replyToPid":0}
发表于 2020-10-19 19:57:55 来自手机 | 显示全部楼层
612787 发表于 2020-10-18 15:39:47 I am thinking Michelin are the best should cost around 3500,I don’t know I am going get some myself.
","text":"I want to know where you are buying 8 Michelin for 3500.00","replyToPid":403647}
GMT+8, 2026-2-12 02:13 , Processed in 0.085884 second(s), 24 queries .
