查看: 211|回复: 8
navigation? which is best
 楼主| 发表于 2020-10-18 13:38:23 来自手机 | 显示全部楼层 |阅读模式
{"text":"what is a good navigation system to use for OTR something that is reliable and accurate with truck routes in the city ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-10-18 14:14:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Garmin, Satellite view Google maps, Waze, an actual paper map and of course TruckerPath. \nI use all those and more if needed. \nThe best, in my opinion, is to ALWAYS preplan from starting point to ending point and all the stops in between.\nI have never been late, unless entire interstate route was closed because of weather, or lost.","replyToPid":0}
发表于 2020-10-19 05:53:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Even with all the technology And all the GPS's out there You can never go wrong with the old school   Randall mcnally Atlas.   learn it know it!!  my two cents","replyToPid":0}
发表于 2020-10-18 21:06:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm going to second stick shift and encourage knowing where you're going at all times. Good pre-trip is better than any gps known to man.","replyToPid":0}
发表于 2020-10-18 22:11:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"The stars never lie","replyToPid":0}
发表于 2020-10-19 05:14:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have you even heard of “Hollywood”...🤪","replyToPid":403637}
发表于 2020-10-19 16:55:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"garmin dezl 7\"","replyToPid":0}
发表于 2020-10-21 05:18:23 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"garmin dezl series is rock solid. garmin is known for making aircraft avionics systems. rand mcnally units are garbage I've had 5 of them stop working over the years."}
发表于 2020-10-23 00:34:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"I really like CoPilot. install on your phone.","replyToPid":0}
GMT+8, 2026-2-5 03:43 , Processed in 0.107097 second(s), 24 queries .
