查看: 264|回复: 10
Food for thought!
 楼主| 发表于 2020-10-18 03:42:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"Always roll your windows down, turn your Ac/ heater off when going up and down the mountains to avoid Engine over heat. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-10-18 21:06:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you have problems with your engine getting hot you probably need a new radiator. Windows up, AC on here 👌🏻 ","replyToPid":0}
发表于 2020-10-18 10:08:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"A Deisel tractor is not a 4 wheel car. Whether or not your AC is on will have zero affect on the coolant temperature pulling a hill. Percent of grade and weight will decide temperature for you. ","replyToPid":0}
发表于 2020-10-18 12:45:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Actually running the heater helps to draw out heat from the cooling system as the heater is a miniature radiator so by running the heat you are running air over another heat exchanger which helps cool heating system ","replyToPid":0}
发表于 2020-10-18 04:33:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not when ur going dwn. Only on long up grade.   ","replyToPid":0}
 楼主| 发表于 2020-10-18 04:53:56 来自手机 | 显示全部楼层
758212 发表于 2020-10-17 20:33:25 Not when ur going dwn. Only on long up grade.
","text":"Noted","replyToPid":403552}
 楼主| 发表于 2020-10-18 10:28:58 来自手机 | 显示全部楼层
655965 发表于 2020-10-18 02:08:17 A Deisel tractor is not a 4 wheel car. Whether or not your AC is on will have zero affect on the coolant temperature pulling a hill. Percent of grade and weight will decide temperature for you.
","text":"I’m not talking about 4 wheeler but okay if you say do. I hear you ","replyToPid":403600}
 楼主| 发表于 2020-10-18 20:25:33 来自手机 | 显示全部楼层
644651 发表于 2020-10-18 04:45:11 Actually running the heater helps to draw out heat from the cooling system as the heater is a miniature radiator so by running the heat you are running air over another heat exchanger which helps cool heating system
","text":"Noted ","replyToPid":403609}
 楼主| 发表于 2020-10-18 22:08:12 来自手机 | 显示全部楼层
945974 发表于 2020-10-18 13:06:23 If you have problems with your engine getting hot you probably need a new radiator. Windows up, AC on here 👌🏻
","text":"Good for you ","replyToPid":403621}
 楼主| 发表于 2020-10-18 22:08:36 来自手机 | 显示全部楼层
794377 发表于 2020-10-18 14:07:40 Just need more power, then big grades are not an issue!
","text":"Noted ","replyToPid":403633}
GMT+8, 2026-2-7 10:07 , Processed in 0.069980 second(s), 24 queries .
