查看: 287|回复: 9
snow chains?
 楼主| 发表于 2020-10-17 10:12:15 来自手机 | 显示全部楼层 |阅读模式
{"text":"First time I've gotta buy my own chains and wondered if there are chains to stay away from or what ones are best. Cams vs straps, what to get what to get. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-10-18 04:06:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"if it's requiring chains you should not be on the road","replyToPid":0}
回复 支持 2 反对 2
发表于 2020-10-18 06:27:44 来自手机 | 显示全部楼层
438324 发表于 2020-10-17 20:06:08 if it's requiring chains you should not be on the road
","text":"how do you make any money in the winter? or get through the mud in the rain? I've chained up 5 different times in one day. you must be old or something.","replyToPid":403546}
发表于 2020-10-17 11:30:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"i use AutoSocks, they are easy to slip on, and work better with ABS brakes than chains or cables.","replyToPid":0}
发表于 2020-10-18 04:06:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"tire socks is what we have on our trucks have never used them","replyToPid":0}
发表于 2020-10-17 10:45:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"ive heard bad things about cable chains. make sure to get yourself some steel links. itll cost you hundreds but as long as you dont lose em you'll be set","replyToPid":0}
发表于 2020-10-18 11:17:23 来自手机 | 显示全部楼层
764614 发表于 2020-10-17 22:28:01 Supersox a good one? Pair are around 129, the others I found were Auto socks starting at 199.
","text":"I know AutoSocks meet the chain requirements in all the states. Just be careful because not all snow socks do.","replyToPid":403575}
 楼主| 发表于 2020-10-18 06:28:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Supersox a good one? Pair are around 129, the others I found were Auto socks starting at 199.","replyToPid":0}
 楼主| 发表于 2020-10-18 02:07:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"I will look into getting some. Thanks guys!!","replyToPid":403465}
发表于 2020-10-17 22:23:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"use only for going to colorado I-70","replyToPid":0}
GMT+8, 2026-4-17 23:49 , Processed in 0.116047 second(s), 24 queries .
