查看: 195|回复: 8
Quitting an OTR job
 楼主| 发表于 2020-10-16 05:47:42 来自手机 | 显示全部楼层 |阅读模式
{"text":"what's the process? Do I give them a notice or will they use that against me until i turn the truck in? Hometime scheduled  to drop my stuff off, should I tell them then and then deadhead to nearest terminal  200 miles away? what's the best way to do this?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-10-16 21:55:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"drive it to El Paso tx an sell it on spot!! they'll drive it down to Mexico","replyToPid":0}
发表于 2020-10-16 07:01:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t abandon the truck. They will charge you for it. I would get routed to the yard and rent a car. No one in my family drives 400 miles besides me. ","replyToPid":0}
发表于 2020-10-16 06:23:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Never abandon the truck","replyToPid":0}
发表于 2020-10-16 06:22:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Vacation first thencome back from vacation get your last check first then tell them I quit. Some companies will keep your last$$$$$$","replyToPid":0}
发表于 2020-10-16 06:02:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"drive straight to the yard and have someone from home drive those 200 miles and pick you up","replyToPid":0}
发表于 2020-10-16 09:33:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"drive by home, drop your stuff, give notice, then if they don't give you a route back to the yard by your last day, deadhead it all the way back. it's  not your fault if they can't plan properly. it kinda just depends on you, but definitely  give notice.  always.","replyToPid":0}
发表于 2020-10-16 07:47:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Remember that when you try to get another job they will ask your older work and it's better to say I give you my 2 weeks notice.","replyToPid":0}
 楼主| 发表于 2020-10-16 22:06:55 来自手机 | 显示全部楼层
941566 发表于 2020-10-16 01:33:16 drive by home, drop your stuff, give notice, then if they don't give you a route back to the yard by your last day, deadhead it all the way back. it's  not your fault if they can't plan properly. it kinda just depends on you, but definitely  give notice.  always.
","text":"this seems like the best advice. Will go this route, thx","replyToPid":403212}
GMT+8, 2026-2-12 02:07 , Processed in 0.122415 second(s), 24 queries .
