查看: 138|回复: 1
OmniTrax ELD Update for new HOS Rules 29 Sept 2020
 楼主| 发表于 2020-10-15 10:12:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"Is anyone else still experiencing ELD malfunctioning for OmniTrax? Approximately 3-10 times a day I get a Critical Malfunction Error Message and the Home Button goes RED. It requires that you manually input all the missing Locations for the last 24 hrs! Yea, good luck remembering what city you passed through 10 hrs ago. We have over 50 units in our fleet all with the same issue. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-10-15 11:56:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"get a patch/update. i had that once when the change 1st went into effect. needed to add 3 locations. then i got a local update & it hasn't happened since.\ncall your eld provider tech support.","replyToPid":0}
GMT+8, 2026-4-18 01:03 , Processed in 0.073673 second(s), 23 queries .
