查看: 486|回复: 9
pre trip/post trip
 楼主| 发表于 2020-10-12 09:28:54 来自手机 | 显示全部楼层 |阅读模式
{"text":"hey everyone I got a leak from my rack and pinion. will I get a fine or be put out of service from this?","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":954.0},{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":954.0}]","canComment":true,"externalShare":false}
发表于 2020-10-14 04:13:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"put your pinion away and tell us more about this rack","replyToPid":0}
发表于 2020-10-13 08:13:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"rack and pinion on a semi\n hahahahahahahahahahahahahah","replyToPid":0}
发表于 2020-10-12 16:28:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"hey I got a answer for you, this has happened to me before to","replyToPid":0}
发表于 2020-10-12 22:49:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes, any oil or grease leak is a violation.","replyToPid":0}
发表于 2020-10-16 01:57:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"I drove a 1969 mack with no power steering in the 90ies was only hard when parking or backing up when your driving wasn't so bad","replyToPid":0}
发表于 2020-10-13 20:54:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"No rack and pinion on a truck. And if you lose power steering, you’ll have to stand  up to be able to turn the wheel. It’s about like wrestling a brar.","replyToPid":0}
发表于 2020-10-12 16:51:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"What’s it like when the steering goes out on a heavy machinery? I’ve never lost steering in any vehicle. I wish I had experienced more car failure before driving a truck. Mostly good cars or bad sensors. Maybe it’s good because that would scare me to drive like that. I never once went, meh. I can handle not steering. ","replyToPid":0}
发表于 2020-10-13 20:56:22 来自手机 | 显示全部楼层
327523 发表于 2020-10-13 12:54:19 No rack and pinion on a truck. And if you lose power steering, you’ll have to stand  up to be able to turn the wheel. It’s about like wrestling a brar.
","text":"Bear. Dang fat fingers. Lol","replyToPid":402509}
发表于 2020-10-15 09:27:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"ANY leak such as this will get you a violation. A leak coming from a steering gear box or hose or pump or reservoir isn’t something to be driving with because trying to steer a big truck without power steering will be a nightmare and highly dangerous at highway speed. ","replyToPid":0}
GMT+8, 2026-4-16 14:30 , Processed in 0.111749 second(s), 24 queries .
