查看: 400|回复: 13
Over hang on front of flat deck trailer how much is aloud
 楼主| 发表于 2020-10-11 01:41:55 来自手机 | 显示全部楼层 |阅读模式
发表于 2020-10-11 20:12:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"if it doesn't extend into the sleeper you're good","replyToPid":0}
发表于 2020-10-11 04:27:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Allowed. Not aloud. ","replyToPid":0}
发表于 2020-10-13 10:01:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Any front overhang on your trailer is legal. It really depends on how long your tractor is. Where you put the front of the load safety is 20\" from the Headache rack. Rear overhang varies from State to state, it also is dependent on what the load is.","replyToPid":0}
发表于 2020-10-12 08:19:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"there isn't a restriction on the front of the trailer but you just have to make sure you can turn and it doesn't hit the back of your headache rack or cab.","replyToPid":0}
发表于 2020-10-11 02:06:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"One foot","replyToPid":0}
发表于 2020-10-11 02:14:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"What? I can’t hear you","replyToPid":0}
发表于 2020-10-11 09:47:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would not go over 2' but it's usually the rear overhang they worry about","replyToPid":0}
发表于 2020-10-11 04:41:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"mine was Two feet overhanging when I was pulled in for a level One. inspection. The DOT guy did not say a word about it.","replyToPid":0}
发表于 2020-10-11 02:17:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"We do 2 ft and you will be okay","replyToPid":0}
 楼主| 发表于 2020-10-13 02:27:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks for the info fellows","replyToPid":0}
GMT+8, 2026-4-18 02:50 , Processed in 0.118753 second(s), 24 queries .
